Vídeos interesantes del GR86
Iniciado por arribi, Enero 05, 2023, 20:57:06
Zeposf3rico
Este es de hoy, no se puede traducir aunque no hace falta, le pone gomas de invierno y a jugar...
Zeposf3rico
Zeposf3rico
Vídeo oficial de Toyota USA comparándolo con el miata  C:-)
2023 Toyota GR86 vs 2023 Mazda MX-5 | Toyota
 2 mar 2023
Toyota USA
In this sports car comparison, we see the 2023 Toyota GR86 vs 2023 Mazda MX-5. With its thrilling road manners, GR86 stands out as a sports car that brings excitement on every drive
0:00 2023 GR86 vs. 2023 MX-5
0:10 Top GR86 Takeaways
0:37 2023 GR86 Grades
1:22 What exterior features are included in the GR86?
3:03 What interior features does the Toyota GR86 have?
3:59 What is GR86's technology package?
5:14  Is the GR86 a safe car?
5:44 How does the GR86 perform?
7:06 Does the GR86 hold its value?
malagon33
NachoCV acaba de subir el vídeo del GR86 de Rubén de Tenerife!!!
Zeposf3rico
Cómo cambiar la pila de la llave
Zeposf3rico
Sabéis algún sitio que hagan esto, pero con las 3 B?
Protecting one of the first UK delivered Toyota GR86 with Xpel Full Car PPF
New Look Detailing LTD
  5 mar 2023
In this weeks video we had this brand new Toyota GR86 at The Studio for the best possible level of protection, Xpel Ultimate Fusion full car PPF. With this all of the exterior painted surfaces will be protected from scratches and stone chips as well as the glass, wheels and interior coated with our wax is dead ceramic coatings.
Xpel is the largest paint protection film provider worldwide and comes with a 10 year warranty so you know you will be well covered!
Get in touch now to get a free quote for your vehicle whether that be for ceramic coatings or paint protection film
Zeposf3rico
Zeposf3rico
Hoy en las antípodas... Toyota Australia
Zeposf3rico
Zeposf3rico
Zeposf3rico
Zeposf3rico
🚗 Vehicle in This Video:
2022 Toyota GR86
MSRP: $27,700
Engine: 2.4L 4-cylinder
Transmission: 6-speed manual
Horsepower: 228hp @ 7,000 rpm
Torque: 184 lb-ft @ 3,700 rpm
Curb weight: 2,811 lbs
MODIFICATIONS:
Enkei TS-10 17x8 Wheels
Kumho V730 225/45R17 Tires
Front & Rear Tow Hooks
Crash & SPC Camber Bolts (-2.4 degrees at the front, -1.3 degrees at the rear)
CSG C21/C11 Brake Pads
Motul 600 Brake Fluid
Jackson Racing Oil Cooler
2018 Mazda MX-5 Miata Club (E85)
Engine: 2.0L 4-cylinder
Horsepower: 170 hp
Torque: 148 lb-ft
Curb weight: 2,300 lbs
MODIFICATIONS:
Ohlins Road and Track 7k/4k spring rates
Flyin Miata front sway bar
Verus Engineering rear diffuser
Fab9 E85 tune
Recaro seats
Hard dog roll bar
Goodwin racing strut tower brace
Flyin Miata oil cooler
Goodwin racing transmission cooling scoop
Volk TE37 OG Bronze 17x7.5+38
Kumho HS51 225/45R17
Ferodo DS2500 brake pads
Aligned by west end alignment, -2.0 camber f/r, 1/32 toe in front, 3/32 toe in rear, 6.5 caster, corner balanced at 2339 lbs curb weight
Zeposf3rico
Zeposf3rico
Zeposf3rico
